extrude/ remove feature
christopher_bosworth
                    Member Posts: 2 EDU
                    i am using onshape to create a phone case, i have a sketch on top of the frame for the phone to cut out a spot for the power button but i cant seem to get the extrude/ remove to work. when i use it it just deletes my sketch and leaves me with the frame of the case when what i want it to do is cut the hole in the case where the sketch was. the error i get is extrude 2 did not regenerate properly and no merge scope selected.
Jake_Rosenfeld
                    To add to Jake's answer:
You can make this work be either selecting the merge scope field and then selecting the case, or just select "Merge with all" if you're feeling lazy:
Jake Rosenfeld - Modeling Team7
And it is most likely not deleting the sketch you are using, just setting the visibility state to hidden. If you find the sketch in the feature list and hover over it, there is an eye which indicates whether the sketch is visible or invisible.
