Chamfer/Round failed in SM model
Hi,
I tried to make a chamfer or a round on the sheet metal model and is not working.
Have you find this problem in your model?
Thank's.
Thank's.
viru Member, Developers Posts: 619 ✭✭✭✭
@icatoiu_daniel, Fillets/chamfers are not currently possible in sheet metal, before 'finishing', but are certainly in Onshape list of things to add in upcoming releases. although not as convenient as chamfer and fillet features, one workaround for now: You can create sketches and extrude-remove material. This works while still editing a sheet metal model and will show up in your flat pattern.
5
You can apply Chamfer after applying this option.But the chamfer which applied after "Finish sheet metal model" option will not reflect in flat view.
You can raise a improvement request for this.
