my insert window won't scroll
john_hoyle289john_hoyle289 Member Posts: 6 ✭✭
When i have more than eight part studios, the last one on the list will not show in the assembly insert window, the window will not scroll, i can't drag the slider. help please.
    @john_hoyle289
    This is a known issue with a simple fix.  Clear the browser cache and refresh.
    It happens from time to time and Im confident onshape will get this ironed out sometime in the future.
    You can also search and this will allow you to get to the parts at the bottom.
  • john_hoyle289john_hoyle289 Member Posts: 6 ✭✭
    Coleman,
    thanks for your advice, i do appreciate it, but it didn't seem to work for me.
    @john_hoyle289
    Submit a support ticket using the question mark icon and the onshape team will take care of you.
    I've got the same problem.
    I select multiple items and drag them, this causes the slider bar to appear on the side, which if you grab it, allows you to move the window freely. It's not easy, but can work.
    This is a definite bug.
