exporting a DXF from imported part uses inches even though my account and workspace are set to mm
Kevin_4
Member Posts: 4 ✭
I have a part that I've imported from Solidworks and I want to export a DXF of it for a router (I can't export the DXF from sldwks without disjoint "vectors") - so in order to join up all the vectors I'm creating a drawing from the imported part in onshape and then exporting a DXF from that drawing.
I've set my account units to mm, and I've set the workspace units to mm - but whenever I export DXF from the drawing - the DXF unit values are inches...
This is the part https://cad.onshape.com/documents/58a5bf9d5aa7880fcd52a000/w/5613047ea4724064f4626046/e/9ec9c1db5ca345f70cd25d86 and the problem drawing (the one I'm trying to export a DXF from) is Part1Drawing1 on that part.
Interestingly - if I select a face on the part and export DXF on that - it correctly uses mm in that exported DXF. That doesn't do what I need though, since again the vectors are disjoint...
1
I'm not surprised it wasn't clear what I meant by "disjoint vectors" - I've no idea what the correct terminology is - so here's some pictures.
This is what I get when I export a DXF from a face and open it in VCarve Pro:
the long teardrops are made up of multiple vectors.
Which is basically a showstopper - However - the dimensions are correctly in mm.
But when I create a drawing from the part, and then export a DXF from that and open it in VCarve Pro
I get this :
the long teardrops are a single vector - which is great - however the dimensions are in inches.
also - just to make sure we're on same page - I assume this is what you meant when asking if I used an MM template :
I too have the "joy" of using v-Carve pro and had the same disjoint problem termed "open vectors".
V-C gives a very unhelpful error message. After much help from google looking for free apps that could join vectors I found a hit that said use the "Join Open Vectors" button, in of all things, V-Carve Pro. FFS (It looks like a rectangle with some node points on it and it can be found in the "Edit Objects" part of the screen.
This does exactly what it says on the tin. So exporting a dxf from a face (without bothering with a drawing at all) is perfectly fine for V-C, and is funnily enough what I've been doing whilst listening to Cody's webinar
Hope that helps,
I'll have some problem!
+1
So what I'm really looking for is correct units being applied when exporting the dxf from the onshape drawing - since those vectors come out whole...
Owen S
Still looking for someone to chime in and explain how to get Onshape to apply correct units when exporting DXF from onshape drawing.
Not by right clicking a face - but like this :
