Can I flatten a sheet metal funnel?
tried to flatten this both from solid and with the slot with no luck, is this possible in Onshape?
https://cad.onshape.com/documents/6999eada732c97d3c0c65a21/w/6dde8a46a184dbac7e9fd462/e/6a72229f5d6cb1d45d962006
https://cad.onshape.com/documents/19f29b16f119ed4bcfd52944/w/59df6d0a42f996e7e6e1163a/e/3fffebd566b25f748653a54f
https://cad.onshape.com/documents/dbdf83c59a653cf03abbb5cb/w/3219a463aef22f82069eca74/e/35f1dd239075c19f0d5727a4
What step were you taking to try to create sheet metal from your lofted solid? When you were inserting bends when converting to sheet metal, did you make sure to leave one rip open?
