sheet metal flanges
stew_schmehl
Member Posts: 4 PRO
in General
i have a flat sheet metal part with an extruded rectangular cut in the center. the four corners of the cut are filleted. i want to flange the straight areas of the cut. so far i have not been able to do it. it's a simple task in SW.
Optionsbradley_sauln Moderator, Onshape Employees, Developers Posts: 373@stew_schmehl You may need to adjust the flange alignment. Part Studio 2 of the included document shows this working. Took a different approach to it in Part Studio 1 where I worked fully as a solid body first and then converted the faces needed to sheet metal: https://cad.onshape.com/documents/d2e655d61437861602e0d579/w/caf1817f481adc251c90decf/e/a75ac9b3521543ac8dfca7fd5
Twitter: @bradleysauln
