Can you reference one dimension in a sketch when entering the value for another dimension?
brian_brady
Member, Developers Posts: 505 EDU
in General
Say I have a simple rectangle. I always want its height to be .4 times its width. Can I do this directly in a sketch? I am particularly looking at situations where I don't explicitly know what the width of the rectangle will be since it is generated by referencing other geometry when it is constructed. This is kind of like using variables, but created on the fly. In Creo (Pro/E) I would look at a dimension's identifier (i.e. d3) and make the other dimension 0.4*d3
Brian
Brian
Jason_S
Moderator, Onshape Employees, Developers Posts: 224
Hi Brian,
No, you cannot do this directly in a sketch. We don't set 'names' of sketches at the moment. I was a long time SolidWorks user and I was used to entering, for example, "0.25*d3@sketch4" in many of my sketches. Feel free to go to here to add your vote to the improvement request for this.
This isn't a solution, but this Measure Distance custom feature allows you to assign an existing distance to a feature, different from our normal Variable workflow. https://cad.onshape.com/documents/572b968ce4b07aad125dbaaf/v/08093fef6c4d4f330f24dd19/e/b40df94c5081948fe8195e81. Give it a try!
Best!
JasonSupport & QA6
Best!
Jason
Here's an example: https://cad.onshape.com/documents/4d46f0309ed541160c60804a/w/23b848821b3ef7439c5657bb/e/1e3a2060562fd41eb43fd561
Brian
https://forum.onshape.com/discussion/15006/improvements-to-onshape-december-10th-2020/p1
This is quite old but I assume not addressed? I have the same problem as brian_brady - complex sketch and a driven dimension, want to reference another driving dimension to this driven dimension. New to Onshape, just moved from SW, easy thing to do in SW but seems not possible with Onshape?
Unfortunately, that functionality isn't available yet. Occasionally, I'll put down two lines, dimension one and make the other one equal to the first to give me that functionality.
For what you need, you can create a Variable and select the option for Measured. Otherwise, the Measure Value custom script adds even more functionality.
Ramon Yip | glassboard.com
