Can I Extrude an imported picture or at least have it visibile in the assembly?
I have inserted an image, a .jpg silouette of a person, and affixed the picture to the current part. On Screen, in the parts view, it looks correct. But when I import the part to the assembly, the visual of the .jpg disappears. I also cannot extrude the .jpg (which I thought would be cool if it would, but am not surprised it can't). Can I get the .jpg portion of the part to show up in the assembly drawing?
NOTE: Reason for wanting this:
This is a CNC'd wood part. We need two steps to create the part. Create the OnShape part, like a 6 x 10" plaque, and then in a separate program, we create a .pdf lettering and/or person siloutte that gets imported into the CNC machine. I was looking to import that .pdf (or picture) into OnShape and Best Case, have the picture be able to be extruded to the thickness of the plaque, or to show up in the Assembly Drawing so we can visually see it (or possibly see it in OneRender).
Is there another way to accomplish this all withing OnShape?
bradley_sauln Moderator, Onshape Employees, Developers Posts: 373
In this case, you will have to use a dxf or dwg file. There are some online converters that can turn .jpg to formats like svg or dxf but its accuracy depends on the image contrast. Onshape needs actual lines and enclosed profiles to do something to.5 -
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
Todd,
Once you import the image as a sketch into a part studio, you can trace the image with our sketch tools, then extrude the faces you create. Here are a couple examples of how this is done:
https://cad.onshape.com/documents/7f02baa672c863febd89cb55/w/86109a9b80a71853f4531b43/e/204d0f05b905ecd4d7cbebeb
https://cad.onshape.com/documents/ec4d9c75a4f6b2b6741f2799/w/790919b65a6679b9e59ec03e/e/2a1630ebfa945ac5703a4289
This will probably be more reliable than an online converter that uses edge detection, and will be a similar workflow to tracing the image in another program.
It is a known bug that Sketch images do not come into assemblies correctly, if you would like to help us with prioritization of that bug, please use the 'feedback' option under the '?' menu in an Onshape Document.Jake Rosenfeld - Modeling Team2
Twitter: @bradleysauln
Hope it helps!
https://youtu.be/Qvf0oN_aNBs
