invalid state at end of execution
cory_isaacson
Member, Developers Posts: 43 PRO
I had a FS feature working fine, then started getting this error. All I did was set the material for parts that were generated. Now I cannot get rid of the error, even if I roll back to before the point of setting the material. Any idea what's wrong? See the attached screen shot.
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,254
Ok, with the debug function hint, I was able to reproduce it and it does look like a regression. Will investigate.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5 -
ilya_baran
I believe it should be fixed now.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
I tracked it down further, it is related to my use of debug. I have a logMessage function that looks like this:
export function logMessage(context, debugFlag is boolean, text is string, object) {<br> if(!debugFlag)<br> return;<br> <br> println(text);<br> debug(context, object);<br>}<br><br>This function has been working fine for months, not sure what is different now.Thanks!
