Will it be possible to import a PARASOLID model w/build history?
I see that Onshape (OS) licenses the Parasolid(TM) kernel as the basis for its 3D modeler. Will there be any effort made to import models from other Parasolid based kernels and retain the model's build history?
Right now it appears you only get a surface BREP.
As a test, I exported a OS model to Parasolid and imported it back in and I only got back the BREP.
My question makes the assumption the Parasolid kernel API supports history based modeling. This assumption could wrong.
Jason_S Moderator, Onshape Employees, Developers Posts: 223
Parasolid does not have history associated with the file type. It just drops a BREP in the document. Feature recognition seems a likely alternative solution to your underlying problem.Support & QA5 -
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
Stephen,
It should be pretty easy to remove holes and other small features. For a hole, just use the 'Delete face' feature on the bottom face and all the side faces of the hole. This can also be done for a protrusion.
The direct editing video on this page gives a much better tutorial than I can give over writing:
https://cad.onshape.com/help/Content/deleteface.htm
(The video on that page also makes reference to the `right click -> Create selection...` workflow which is extremely useful for deleting all the faces in a protrusion or a pocket)
Hope this helps!Jake Rosenfeld - Modeling Team2
I have seen enough of feature recognition products to know to keep walking when approached by a salesman.
A BREP is sometimes better that trying to unravel/understand a build process and 2D sketch schemas.
How easy it to remove holes and other small feature details? Or is it better to create "bondo" features to fill unwanted voids?
Hope this helps!
