Alternative to Shell?
Apparently, the Shell tool isn't what I'm needing, but the attached screenshot will show what I'm wanting to accomplish. Yes, I'm still a newbie to the CAD world and have only been "trying" to learn this for a few months now. What would be the alternative to the Shell tool in order to take the ends out of this extruded cross?
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
Shell should still work fine. The Shell feature lets you select more than one face to remove.
6
I avoid shell on complex models and rely on building the inner & outer geometry. It's actually faster to build it manually on complex parts than using the shell command.
I think with your geometry, you'd fine this approach much more rigorous/tedious. I agree with mahir and would stick with the shell command. For what you're doing, it's best.
