can I do a boolean subtraction in assembly on an ipad pro?
chip_brettell
Member Posts: 4 PRO
If a part interferes with another part in an assembly, can I remove the interfering region from one of the parts? This is on an ipad pro...
NeilCooke
Moderator, Onshape Employees Posts: 5,938
If both parts belong to the same part studio, then yes, but if they only interfere in the assembly then you must use in-context editing which is not yet available on iPad (you must do the edit in web browser).Senior Director, Technical Services, EMEA5
