Rib along a 3D-trajectory
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 266 ✭✭✭
edited March 2017 in Community Support
I like to make a rib along the yellow 3D-curve in the picture below.
In that picture the shape of the rib is also visible in the 5 sketches.  I started with a sweep with one of the sketches along the curve. That did not give the right shape.
Then I tried a loft, see picture below. That looks good. But… when I select the yellow curve as guide, the loft fails. Probably because the round segment is not a 2D-sketch?
How can I create the rib along the curve?
Reference: https://cad.onshape.com/documents/0a1d05a3ea4d5a43c4ffa30d/w/0de9a8be5871399fffc9b80a/e/df2bf44f852c98556ba74542
  • homerhomer OS Professional, Developers Posts: 4 PRO
    A combo actions of thicken, offset face & boolean could make it work. In terms of design intent, u only need to adjust the amount of thicken & offset face when changing the thickness of the rib is needed.
    http://cad.onshape.com/documents/58c6c1b83e5d5c0ff12ee2a3/w/eecb0e5b7fedd2ccf2c1d1f6/e/03fe3377c9fb8917fe10c3a4
    edited March 2017
    I also couldn't create it with Loft but did something similar with Sweep and Thiken
    https://cad.onshape.com/documents/58c50b0e786ec50fe9e08919/w/e4387c77c6e0ddfef3106270/e/1a285042bfea7dc50d189f02
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 266 ✭✭✭
    @konstantin_shiriazdanov thanks for your answer and solution. The idea behind it is clear and can be used as a work around.
    However, when this is the way one should make the rib then the OS team has a challenge to design a more comfortable solution.
  • Ben_MisegadesBen_Misegades Member Posts: 133 ✭✭✭
    Seems like this is just a shortcoming of capabilities within OS, so far, and I'm sure more functionality will be added. Things like "twist along path," more options for guide curves and profiles, the ability to set end conditions while also using guide curves, more intelligent interpretation, etc.
    Some images of failed attempts:
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,038 PRO
    That is clean @homer
    nicely done
    Agreed, that is a nice work around. The top surfaces of the rib are rounded, of course, but that may be perfectly OK for the design intention
    edited March 2017
    Nice work @homer.
    @ben_misegades, a flat top surface is the intention indeed. So this rib does not meet the specs. But I agree that this is fortunately not important in this case.
    However, it indicates again, as we know, that OS cannot model all needed geometrie at this moment.
