Rib along a 3D-trajectory
Henk_de_Vlaam
Member, Developers Posts: 266 ✭✭✭
I like to make a rib along the yellow 3D-curve in the picture below.
In that picture the shape of the rib is also visible in the 5 sketches. I started with a sweep with one of the sketches along the curve. That did not give the right shape.
Then I tried a loft, see picture below. That looks good. But… when I select the yellow curve as guide, the loft fails. Probably because the round segment is not a 2D-sketch?
How can I create the rib along the curve?
Reference: https://cad.onshape.com/documents/0a1d05a3ea4d5a43c4ffa30d/w/0de9a8be5871399fffc9b80a/e/df2bf44f852c98556ba74542
elif
Onshape Employees Posts: 53
It looks like you attempted to select a multi-edge guide. Currently, we have a limitation that a multi-edge guide can only be selected as a sketch from the feature list. We are aware of this limitation, and we will be improving multi-edge selections for guides and profiles in the near future.
5 -
homer
OS Professional, Developers Posts: 4 PRO
A combo actions of thicken, offset face & boolean could make it work. In terms of design intent, u only need to adjust the amount of thicken & offset face when changing the thickness of the rib is needed.
http://cad.onshape.com/documents/58c6c1b83e5d5c0ff12ee2a3/w/eecb0e5b7fedd2ccf2c1d1f6/e/03fe3377c9fb8917fe10c3a4
2
https://cad.onshape.com/documents/58c50b0e786ec50fe9e08919/w/e4387c77c6e0ddfef3106270/e/1a285042bfea7dc50d189f02
However, when this is the way one should make the rib then the OS team has a challenge to design a more comfortable solution.
Some images of failed attempts:
nicely done
@ben_misegades, a flat top surface is the intention indeed. So this rib does not meet the specs. But I agree that this is fortunately not important in this case.
However, it indicates again, as we know, that OS cannot model all needed geometrie at this moment.
