Issue Exporting Text engraved in part
patrick_LOGrepatrick_LOGre Member Posts: 12 ✭✭
Hello
I made a simple part and add text on it.
Then extruded (w remove option) the text from the part. result is ok.
But when I export this in DXF format for laser cutter/engraver, the result is bad.
The inner parts of the letters are missing.
what to do ?
thanks
    Patrick,
    The best thing to do in this situation would be to submit a support ticket via the 'feedback' option under the '?' menu in your document.  That way we can have all of the relevant information and try to triage your issue.
  • patrick_LOGrepatrick_LOGre Member Posts: 12 ✭✭
    ok. will do. thanks.
    unfortunately, as free user, ticket is not supported.
    Nevertheless, the issue does exist :)
  • lanalana Onshape Employees Posts: 727
    @patrick_LOGre
    When exporting the face after cut , you are not selecting the inner parts of the letters, because they are separate faces. Try exporting the sketch containing the text. That should work better.
  • michael3424michael3424 Member Posts: 729 ✭✭✭✭
    Wait, what?!?!?  Are tickets not supported in the free plan?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,231
    They are supported, just called "Report a bug" rather than "Feedback"
    Just logged in with my free account to check this.  I see the "Report a bug" option under the "?" menu as expected.  Sorry for the unclear instructions earlier (to click the 'feedback' option), I believe the name of this menu option changed recently to be more clear.
    To be clear: "Report a bug" will submit a support ticket to our team. This works for all users, free or pro :smile:
    Thanks Ilya and Jake - Mike
