Do editing logic functions work with enums?
Lee_HeskethLee_Hesketh Member, Developers Posts: 148 ✭✭✭
edited April 2017 in FeatureScript
Do editing logic functions work with enums? If so, how do I implement it?
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,923 image
    edited April 2017 Answer ✓
    Try something like:
            if(changedDefinition.myEnum == myEnum.ONE)<br>             changedDefinition.length = 1*inch; <br>       if(changedDefinition.myEnum == myEnum.TWO)<br>             changedDefinition.length = 2*inch; <br>    }<br>    return changedDefinition;</code><h2><pre class="CodeBlock"><code>if(oldDefinition.myEnum != changedDefinition.myEnum)<br><code>    {<br>
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    They do -- as with the other parameters, you set the changed enum in the returned definition of the editing logic function.  What is the difficulty you are running into?
  • Lee_HeskethLee_Hesketh Member, Developers Posts: 148 ✭✭✭
    Well, I am checking if the enum is a certain value and setting another value to an arbitrary value.
    export function defaults(context is Context,id is Id, oldDefinition is map, changedDefinition is map) returns map
        if(oldDefinition.myEnum==myEnum.ONE)
            changedDefinition.legnth = 1*inch;
    But nothing happens and  don't know why.
    I don't see an issue here.  Does the error pane show anything?  Sharing the document may help.
    Also, you need isCreating in the logic function parameters if you want this to work on existing features.
    It works if I change the value after the if statements, just not in them.
    I fixed it, damn you misspelling!
    Now there is another error, for some reason, the value set if the enum is TOP should be 64 and 128 if it is BOTTOM. However, they are switched. I haven't changed this in the code. Why is it doing this?
    It's because you're checking oldDefinition instead of newDefinition.  It's checking where you're switching *from*.
    Ah, so would I just change it to newDefinition?
    Yes -- check the value in newDefinition.  oldDefinition is primarily there to see what's changed, not what a parameter has changed *to*.
    Okay, now there is another problem. The value is now fixed, as soon as I change it, it changes itself back to 64mm
    Try something like:
    Thank you so much!
