Do editing logic functions work with enums?
Lee_Hesketh
Lee_Hesketh Posts: 148 ✭✭✭
edited April 2017 in FeatureScript
Do editing logic functions work with enums? If so, how do I implement it?
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
  • NeilCooke
    NeilCooke Posts: 6,097 image
    edited April 2017 Answer ✓
    Try something like:
            if(changedDefinition.myEnum == myEnum.ONE)<br>             changedDefinition.length = 1*inch; <br>       if(changedDefinition.myEnum == myEnum.TWO)<br>             changedDefinition.length = 2*inch; <br>    }<br>    return changedDefinition;</code><h2><pre class="CodeBlock"><code>if(oldDefinition.myEnum != changedDefinition.myEnum)<br><code>    {<br>
  • ilya_baran
    ilya_baran Posts: 1,273 image
    They do -- as with the other parameters, you set the changed enum in the returned definition of the editing logic function.  What is the difficulty you are running into?
  • Lee_Hesketh
    Well, I am checking if the enum is a certain value and setting another value to an arbitrary value.
    export function defaults(context is Context,id is Id, oldDefinition is map, changedDefinition is map) returns map
        if(oldDefinition.myEnum==myEnum.ONE)
            changedDefinition.legnth = 1*inch;
    But nothing happens and  don't know why.
  • ilya_baran
    I don't see an issue here.  Does the error pane show anything?  Sharing the document may help.
  • NeilCooke
    Also, you need isCreating in the logic function parameters if you want this to work on existing features.
  • Lee_Hesketh
  • Lee_Hesketh
    It works if I change the value after the if statements, just not in them.
  • Lee_Hesketh
    I fixed it, damn you misspelling!
  • Lee_Hesketh
    Now there is another error, for some reason, the value set if the enum is TOP should be 64 and 128 if it is BOTTOM. However, they are switched. I haven't changed this in the code. Why is it doing this?
  • ilya_baran
    It's because you're checking oldDefinition instead of newDefinition.  It's checking where you're switching *from*.
  • Lee_Hesketh
    Ah, so would I just change it to newDefinition?
  • ilya_baran
    Yes -- check the value in newDefinition.  oldDefinition is primarily there to see what's changed, not what a parameter has changed *to*.
  • Lee_Hesketh
    Okay, now there is another problem. The value is now fixed, as soon as I change it, it changes itself back to 64mm
  • NeilCooke
    Try something like:
  • Lee_Hesketh
    Thank you so much!
