Request for help - a catenary
 grzegorz_kondracki
                    Member, Developers Posts: 23 PRO
grzegorz_kondracki
                    Hi,
I often have to draw the power of the hoist using flat cables. As it is in the drawing.
These are a catenary. Now it draws with bows and lines but as I change the size of the overhang or spacing between the cable trolleys it spoils everything. Then I use sweet.
The second thing is a bit hard and boring work. In addition, the cables are twisted and it's just fun. How fast can you do and if you change the spacing etc. do not spoil and do it faster.
I was thinking about FeatureScript, sometimes I do my own featureScript, but I do not know whether it is with this handle, curves, tangency, etc. It would have to be similar to wire but for flat wires.
Maybe someone has an idea. You can do it "manually" but it is very time consuming and boring. Then change and red everything on sketch.
Grzegorz (Greg) Kondracki
To drive 3D spline I draw semi-constrained frame:
I'm sure you can find rules for the frame to constrain cable to update in desired way.
https://cad.onshape.com/documents/5b67de4c7e846adea64d7893/w/4b0cb527c4659e0dab414a41/e/48b1f0e6f9c867711b6122b7
PS. Miło zobaczyć kogoś z Polski.
Powodzenia
Michał
projektowanieproduktow.wordpress.com
Just to clarify are you looking to:-
(a) Change the design and have the cable update to the correct size
(b) Keep the existing design but have the cable rebuild as the trolleys move (keeping the total cable length the same).
I feel with some combination of the existing measure distance featurescript and some In-Context design either should be possible.
Regards OwS.
Greg
PS. Dzięki Michał. Miło spotkać kogoś z Polski - teraz wiem, że nie jesteśmy sami :-)
Powodzenia
Grzegorz
The cable length is incorrect, but it's due to the fixed angle of my driving frame. Angle should vary, and It would be a complex relation, rather.
Another thing, your file is public, you know now it's under MIT license (at least similar), anyone can use it for any purpose.
I used the end of the jib and parallel but the rope is moving around the disc - you see the film.
I take it back, I just did it, somehow....stand by
OK, so somehow it works by picking endpoints and the arc, but it seems very buggy and only works sometimes. I'm trying to figure out the exact workflow to get it to work, but I think an IR may be in order to make it work more consistently.
