SIMSOLID analysis of a leafspring
KenWelch
Member, Developers Posts: 22 PRO
This is an example of what is possible using SIMSOLID with Onshape. The model is a leaf spring assembly with full geometry detail, including threads on the bolt, etc. The analysis uses pin joints and sliding contact. SIMSOLID does not use FE meshing, so the geometry is solved directly. The simulation is solved adaptively with 3 solution passes. With each pass, the absolute errors in the model are evaluated and the equations are locally enriched to improve the solution quality. Total time for the entire solution process (to create the equations and solve them adaptively) is under 20-seconds. Total time CAD-to-results is about a minute or two.
SIMSOLID is intended to do rapid design-analysis of real world assemblies and complex parts. Attributes of SIMSOLID are:
- can solve the original design geometry without laborious simplification.
- can handle multi-scale geometries with both big and small or thick and thin geometries.
- does not require a mesh
- can handle complex connection types such as bolts, spot, laser and fillet welds
- can do linear static, modal, thermal, thermal-stress and geometric non-linear static analyses
- best of all, it will automatically update all analysis definitions to accommodate Onshape design changes. No more starting over with each design modification.
SVP & Co-founder SimSolid | Altair Engineering Inc.
twitter: @ken_welch | web: www.altair.com/simsolid
If you've done analysis before, you'll pick it up fast and you'll begin to appreciate how easy a meshless FEA is to use. If you haven't used FEA before this is the place to start because you don't have the get things to mesh.
I'm starting realize how revolutionary this new analytic tool is to the engineering community.
Thanks,
Brian
