Solidworks Assembly import - Organising parts
dip_designs
                    Member Posts: 1 ✭
            Hi guys,
Just experimenting with SolidWorks import. Although assembly import is fine I’m finding OnShape simply dumps the parts into one Parts Studio - with each part being stacked one on top of another.
Even with 10 parts it gets very messy to keep hiding and un-hiding parts to edit individual parts. (unless I’m using OnShape wrong!)
Is there away to transfer these parts into their own separate Parts Studio tab? Currently I can duplicate the parts studio and apply a delete feature but that is just as messy and tedious.
(I have a little OCD
SW > Parasolid > Onshape is getting slightly better results than Pack and Go for me at the moment but Parts are still being dumped into one Tab!
Thanks,
Dave
                1
https://cad.onshape.com/help/#uploadfiles.htm%3FTocPath%3DImporting%2520%2526%2520Exporting%2520Files%7C_____1
Any other thoughts on how to address this?
Thanks,
Aaron
I have tried to achieve better structure by importing as a total assembly exporting specific assemblies then re-importing to get a broken down or flattened part studio. This kinda works but you have to know your structure and plan it so you don't have to do much re-assembly, have double ups or missing of multiple instances. I'd only do this if the original CAD data was completely redundant and I planned to move across to Onshape and see valve in spending time on the structure.
Ideally, I'd love to be able to import an assembly and have all the parts come into the part studio in the position of the original assembly, with some options to chose the most appropriate instance.
Some project I have had to work with others on a different MCAD systems and reimport their files to Onshape after they have updated to a new version. This can be a pain as all links are lost. I really hoping that soon we will be able to update an imported part from another system and maintain mates, meta-data and any other links.
