projected curve
joerg_haasjoerg_haas Member Posts: 1
greetings
joh
  • michał_1michał_1 Member, Developers Posts: 215 ✭✭✭
    It looks like original curves can't touch each other:
    At the top of sketch 2 there is an inflection (meaning the curve goes back on itself). This would create a curve that self intersects and fails (imagine extruding 2 surfaces and trying to trim one with the other).
    edited April 2017
    Maybe I was a little hasty with that last post. Self intersecting curves give multiple results. Perhaps a gap is required (I will ask later when HQ wakes up)?
    I was able to recreate something simpler with touching curves that worked. Must be a self-intersecting issue. Stay tuned.
