Is it possible to import a Fusion 360 .f3d file
chris_sulewskichris_sulewski Member Posts: 3 ✭✭
Is it possible to import a Fusion 360 .f3d file?  When I tried, it shows as "non translatable".
  • øyvind_kaurstadøyvind_kaurstad Member Posts: 234 ✭✭✭
    No, not possible. And not likely to ever be possible, I think. A .f3d-file is a complete archive of the design, including all the operations. This will never be translatable (at least not without an extreme amount of work, and not likely to fully support all operations anyway), so you'd be better off just exporting the solids from within Fusion 360 (as STEP files), and then import those to Onshape.
    edited April 2017
    Chris,
    These are the file types we support:
    https://cad.onshape.com/help/Content/translation.htm
    And how to import them:
    https://cad.onshape.com/help/Content/uploadfiles.htm
    Happy cadding!
