Creating Beam Profiles
NeilCooke
Moderator, Onshape Employees Posts: 6,007
The custom feature called Beams comes with a limited set of steel profiles. As requested (by many), I've created the video below to detail the step-by-step process of how to create and add your own profiles.
This video refers to the original method of creating custom beam profiles. This method still works, but in the latest version of the Beams feature, you can now also select a sketch from another Document and use it directly. A video of how to do this can be seen halfway down the page here. This saves you having to create profiles using the method below and also means you don't have to maintain your own personal copy of the feature.
7
Thanks, Jackson
https://forum.onshape.com/discussion/6077/profiles-library-beams
Anyway would be good to merge profiles libraries made by several people (whoever has any valuable inputs) into one common FS.
Just adding a new style of profile and all the }}}}{{{}{}{}{};;;;;;;;:,, symbols gets confusing.
If it helps you any, try "Folding" the code by using the little arrows next to the line number
those will collapse some groups of { & } to help visualize the code a little easier
I finally had some time to put in on @NeilCooke 's FS beams. Since I am in the US and @grzegorz_kondracki added in so many EU profiles, I have focused on ANSI profiles for steel.
I made it through:
L Angle
C Channel - Structural
I/S Section Beams
Sch 10 pipe
Sch 40 Pipe
Sch 80 Pipe
DOM (Drawn Over Mandrel) Tube & Bushing Stock
Rectangular Tube (RHS) - Mechanical
Rectangular Tube - Structual
Square Tube - Mechanical
Square Tube - Structural
I plan to do further work on the list as I have time, but this was enough for now;) . Aluminum profiles will be a big group for sure!
I also had fun using configurations to drive the sketches from a couple dimensions, thanks Onshape for configs!
https://cad.onshape.com/documents/661b4cdeb6c1518cd9c394e3/w/3f38e99b9e74b7d16c7acf14/e/68a64af678f0bd1e6365b99e
-Jackson
So are you looking for one sketch per profile type rather than for each size? That’s still a lot of work.
i am trying to add new custom profiles but i couldnt succed to show them i am putting a print screen of the code, doenst give me any error but when i am trying to use the feature it doesn't show the new "standard" that i created "Custom franco"
Wait until the file has finished commiting
If you are using beam feature in another document, you will need to create a version, then update your other document as well
i leave the link to see if for you guys it works ( i am haing some problems with my account i cant use drawings already in contact with onshape support , so maybe it is only me.....)
https://cad.onshape.com/documents/f0f9a6681e6ca61d815c8116/w/7dbdb3af8e542ccd446992e2/e/c55f391c123fbf78fbce9c80
You need to add your profile set to the list for the Precondition as well:
