Profiles library - beams
Hi,
To use the library of European steel profiles.
We are very happy with the fearutescripts beams - very good job.
We do a lot of frame, boom etc.
For example - boom
There are many different profiles in the library - sometimes all.
For example: beam INP, IPE, HEA, HEB, HEA, etc.
Various types of pipes and rods.
link onshape:
https://cad.onshape.com/documents/58d12b42203be30fcd005b4f/w/d8c0bef6f26d5604b06881b2/e/5fa60f80861479ec429cef9c
link Youtube
link onshape:
link Youtube
We will expand the library as we have free time and need to use the following profiles.
Profiles according to other regulations we can introduce but we need profile drawings and someone later has to check it and we are not running eg in inches.
Grzegorz (Greg) Kondracki
8
Thanks also to @NeilCooke for writing the FeatureScript beams tool.
Owen S.
HWM-Water Ltd
Best regards Brian.
Here is the original beam feature link as written by @NeilCooke. I think Neil has already added Grzegorz ISO profiles into as std. https://cad.onshape.com/documents/e15c2c668d138f01242d0c80/v/f2c6e83e8fdc9123202f01d6/e/2d5660fc1012df9598f00251
You can add your own profiles or find other public beam features with already created geometry.
This feature script as done by @jackson_king has a good selection of ANSI profiles.
https://cad.onshape.com/documents/661b4cdeb6c1518cd9c394e3/v/df3a4465168c3082b1aa8c41/e/d039d04cd820a37795a08d3a
Ideally, Onshape needs to come up with an integrated Beam/Weldment feature rather than the feature script workaround, with a more user-friendly method of creating and adding profile libraries. I also personally want an Australian and New Zealand Profile steel section library but keep putting off creating it in the hope we will see an integrated Beam/Weldment feature, however, this still could be a while off.
Twitter: @onshapetricks & @babart1977
