2 plates at an angle to each other
pcbtmrpcbtmr Member Posts: 13 ✭✭
edited April 2017 in General
This is probably very simple to do but I haven't figured it out.  I have a cylinder and 2 identical plates.  The plates are to be end-plane tangent to the cylinder and at 60° to each other.  Any mates I have tried set the plates at 90°.
Any suggestions much appreciated.
Moderator - This needs to be moved to Community Support.
    You could use angle offset for mate connector?
  • pcbtmrpcbtmr Member Posts: 13 ✭✭
    I was able to do a 30° angle offset.  The second instance of the plate had to be flipped (which only really works assuming the plates are symmetrical) to achieve the full 60° separation.
    Thanks.
