How to select the outer edges of a face?
Hi! I'm trying to achieve a pretty simple thing, I just can't figure out how.
I have an object created by extruding a shape with many edges with holes in it, like this dummy one:
Now i want to chamfer the outer edges of it, not the holes. This is essentially what I want to achieve:
If I select the face, it will chamfer the holes, so the only possibility is to select the other edges one-by-one. That's not so bad in this case, but I have some much more complex shapes and it gets really annoying for them. So, is there a way to select the outer edges only, all together, or select the face and then deselect some (in this case the inner) edges of it for chamfer/fillet? Thank you!
If the locations of the holes are defined from the un-chamfered edges, you can still make the sketch before the chamfer, just move the hole feature below it.
I am thinking if there is another way.
I recall a demo of featurescript that added a chamfer to all edges of a part. Presumably with just a query of all edges owned by the target part and a chamfer command. So could we dig that out, add an extra input field for an "omit these edges" selection and hey presto?
That said, if the number of holes changed (increased) - the new holes would have a chamfer.
Two potential solutions would be (a) put the hole feature after the chamfer or (b) a custom feature that identified (and chamfered) outside edges only.
Want to write it?
Good points. Can't justify the time today but will have a play at the weekend.
Cheers, Owen S.
