How do I weld in during assembly?
Hi,
How do i weld my parts when I have assembled them?
Thanks
Thanks
We do not currently have support for weld graphics, but you can use a fastened mate to attach two parts at a specific location:
https://cad.onshape.com/help/Content/mate-fastened.htm
If you would like additional support for welds, please raise an improvement request from the menu on the right and describe in more detail what you would like to see in the product.
EDIT: Thanks for the weldments example Philip!
If the product can't show welds then it is fundamentally flawed - its a huge problem
1) Working in an assembly studio or part studio and want to see the welds in 3D. (We don't have a weld bead or weld fillet tool yet).
2) Asking about weld symbols in drawings (we're working on them).
3) Something else...
A weldment is unique in that it is a single part with a part number.
Here's how to make one with or without weld beads
1) Make an assembly of the individual parts (each has a part number)
2) Create a brand new Part Studio 'In-Context'
3) 'Transform' (copy into) the new Part Studio those parts that will become the weldment
4) Boolean the constituent parts (you now have one new part (the weldment))
5) Give it a name and a part number
6) Optionally fillet or chamfer the welded joints to represent a concave or convex welds
Philip
https://cad.onshape.com/documents/590a2ea57be40f0ffec8ebee/w/83a9ff55ae7c041eaf0383f9/e/e8ddf59811c55ad691c5362b
So, Philip's solution seems to be a good one.
(except for one thing, I just realized. The separate parts may not touch or overlap, in which case a boolean will not work, and will require some fake geometry to be added to make it work.)
If you use the frames tool, it will create it for you.
There is no way to show "3D" welds automatically, although I am not sure how useful that would be (other than for renderings), although there are a couple of featurescripts for "welds" that might help...
