Has anyone developed a simpler method to design a closed ended compression spring since Feb 2016?
katherine_williams
Member Posts: 3 EDU
chrisjh777 Posts: 93Member ✭✭✭
Compression Springs with closed ends (and with and without ground ends) here:
https://cad.onshape.com/documents/56b7166be4b08910278c4fdd/w/616b75f1743012bd0b525f0a/e/ffe1b502d6c2d4824ae15d1a
I am unable to get this to work....
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
I did this using Parametric Curve. I don't think it's a better method, but it was an interesting exercise getting the equation right and doing this using the fewest features possible.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/9f334d884b522c64159c0322
6
What part are you having trouble with?
Check this out, it may be perfect for this
https://www.youtube.com/watch?v=gIwbW4I8P24
You may want to try using composite curve with the helix, and then using 1 sweep instead of boolean 3 separate sweeps
