Revolving a Chamfer: "self-intersecting part"
Hi Onshape community,
I'm building a cube part which needs a chamfer or fillet around a radius at one end.
Here's the model in question:
https://cad.onshape.com/documents/b85abe8bdcf5d2c7143f049a/w/51f6d0201850ae8454cf22cc/e/2a79e73cd5fb80646ca7ce76
I'm attempting a revolve in remove mode to cut a chamfer on the part around a radius. I can't find another way to do that with the Chamfer or Fillet tool. It just wants to cut the corners along the square. This part will be lathed.
The error I'm getting when trying to rotate elements of Sketch 2 around the axis is: "Resolve1 did not generate properly. Resolve would create self-replicating part. <- Sketch 2"
FWIW I've also tried this with a triangle shape, rather than a radius, as searches popped up other people having this problem trying to create domes and spheres. Same issue. Also, changing the Revolve Type has no effect.
What on earth is going on?
Optionsmahir Member, Developers Posts: 1,291 ✭✭✭✭✭You're probably creating degenerate geometry (knife edges). Change your sketch to look like this, and it will work.
But I don't think that's the look you're trying to accomplish. If you change the sketch plane, you can make the "fillet" start right on the corner. You end up with this more polished look.
https://cad.onshape.com/documents/ff35a763860bd9a6eb7448a0/w/8ea63a4b6f8f2356ea3a6cea/e/07fa1fd5ff7d6f318410c363
5
AAAAND all a guy has to do is open his big mouth for the solution to become obvious. Custom plane. Got it.
We need more pre-selection cleverness in OS
Owen S,
