Select Axis to be something other than an edge, eg center of mass, origin in Z axis, etc
Lyle_Walsh
Member Posts: 46 ✭
When trying to transform or make a circular pattern, an axis of rotation is required. Must this be and edge of some object? Is there no way to select the center of mass or the center of the bounding box or the origin and pick one of the cardinal axiis?
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
i would try to create a sketch with cutout profile directly in the place where you need first cut and then use circular feature pattern. if you share a link to the document it would become more clear what to do in this particular case
5
