"Operation cannot be completed as it would modify a saved version"
I'm getting this message when I try to move parts/assemblies using "move to new sub assembly" command.
Anyone know why?
Anyone know why?
Tony_C_ Member Posts: 280 PRO
Guess I found a "fix"
I was selecting via a window and encompassing assemblies to add to the new sub-assembly.
When I manually selected each assemblies and parts in the instance tree window I was able to move what I wanted to the new sub-assembly.0
I have the same problem, could you explain your fix? I am trying to move parts in the assembly tree but get this message.
