Limiting decimal precision in print() with Regex
I am working on making a simple CAM drilling feature script.
https://cad.onshape.com/documents/b571df08ddf1c4635358bf69/w/110a6ada5e5acec1cbc03228/e/fc6f2559c19db616bda0b63c
I need to limit decimal precision because many controllers, and some G code senders choke on long numbers.
I started by multiplying rounding and then dividing to trim the decimal places, but that didn't guarantee only four decimal places in every case. so now I am converting to strings and using a regular expression to trim the trailing digits off, however my expression is failing in some cases and I don't know why.
Here is the expression in question:
(-?\\d*\\.\\d{1,4}|^\\d$)
and Broken down:
-? = optional minus sign
d* = any number of digits
.d{1,4} = a decimal place followed by one to four digits
| ^d$ = or if it's not the previous format it's just a single digit
It's failing on numbers like 0.4 with a single digit a decimal and a single digit. I am certainly no master at Regex, I can't figure out why it isn't caught by the first case?
Maybe I'm all off course and there is a simpler way to do this?
and Broken down:
Rootentity Member Posts: 21 ✭✭
I've solved this problem, I was using REGEX_NUMBER_CAPTURE to capture everything left over and this was causing the trouble. I've replaced the expression with this "([\\d-]+\\.\\d{1,4})\\d*?" The \\d*? at the end accounts for all of the remaining digits after the needed four digits.0
