Offset plane issue
scott_caskeyscott_caskey Member Posts: 53 PRO
I opened a new partstudio....    I clicked on the Right plane, selected insert offset plane, then inserted an offset plane 5" from the right plane and checked the green box.  Then I tried doing that again to get a plane on the opposite side of the Right plane. It won't create the plane, the plane properties box will not allow me to select either the right plane or the new plane created.   WTH?
  • lanalana Onshape Employees Posts: 746 image
    @scott_caskey
    Is it possible that you have both planes selected?
    With single plane selection I have no problem creating the second plane
    Please file a bug via ?->Feedback menu if this did not unblock you.
  • scott_caskeyscott_caskey Member Posts: 53 PRO
    It won't allow me to select any planes!
    Neil, you are correct!  Thanks.
