Offset plane issue
I opened a new partstudio.... I clicked on the Right plane, selected insert offset plane, then inserted an offset plane 5" from the right plane and checked the green box. Then I tried doing that again to get a plane on the opposite side of the Right plane. It won't create the plane, the plane properties box will not allow me to select either the right plane or the new plane created. WTH?
NeilCooke Moderator, Onshape Employees Posts: 5,896
Hi @scott_caskey - out of curiosity I tested your workflow and got the same results. It wasn't until I looked again that I realised that for the second plane I had selected "Offset surface" command by accident instead of "Plane" - the icons are next to each other.
Senior Director, Technical Services, EMEA5
Is it possible that you have both planes selected?
With single plane selection I have no problem creating the second plane
Please file a bug via ?->Feedback menu if this did not unblock you.
