Box joint feature script
How do you use this feature script. I have created two parts (blank drawer sides), when I select both parts the box joint name turns red and stays that way.
I've tried parts that are touching, parts that are not touching, etc., No worky.
ilya_baran Onshape Employees, Developers, HDM Posts: 1,234
Hi Scott,
The parts need to actually overlap (i.e. the joint feature only removes material).
BTW, if you post a link to a public document where you're experimenting with this, the folks on the forum will be able to help you more easily.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
