How do I extrude a rectangle so it tapers to a line?
Hi guys,
I'm trying to extrude a rectangular sketch so that it tapers to a line on a plane I created above it. I tried using extrude and loft but neither of these seem to work. Can someone help me please? There's a screenshot below and here's a link to the part: https://cad.onshape.com/documents/015506ae8a162909a0c024ef/w/570d117d9e40c61a6e42e9f7/e/a00ad12b312a1a7784dbcbb0
Thanks in advance for any help.
emagdalenaC2i Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
You can see the document here https://cad.onshape.com/documents/f52d6f66f99ee20583129f53/w/986f80bb08ae65c563eecf7e/e/e817fd018681dd0be250bdb8
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común5
You can extrude up to a vertex but you can't do that up to a line.
You can create a loft between the face of the base and a vertex of that line, but you can't select the line
Instead of that you can create a simple sketch and extrude it (You don't need to create the Plane 1 and the Sketch 3)
Seems to work OK though. Have a look.
https://cad.onshape.com/documents/533e9b0d983214cca92d426c/w/bd537698fa5b6d87f36d9e0c/e/bb03a1b2eda267fdc467fba2
