How did I end up with 85 copies?
Lyle_WalshLyle_Walsh Member Posts: 46
another beginner question:
Somehow I ended up with 85 copies of my part, all with the same name.  I closed and re-opened and they are all still there.  Clicking on them acts like they are indeed the same object!
https://cad.onshape.com/documents/88e7c1789a53f86b24afc175/w/d6e3312c1431eddf480347a6/e/a6d0bae979b312884ac33202
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    I think your boolean in the "Half of the Rod" tab is not working correctly -- producing 84 parts, that are then derived into the Full Rod part studio.
  • Lyle_WalshLyle_Walsh Member Posts: 46
    OK I see it now, they are derived from the circular pattern in half rod step where i cut the ridges in that section.  They didn't go away on Boolean so they seem to be left over from the boolean subtract - however keep tool is off!
    Do I need to delete those parts?  THey all seem to have the same name, that is worrisome
