fixing dangling view?
Any tips on how to fix a dangling view? I tried grabbing the detail center point and reattaching but that did not work. The best I have found it to delete and add, is there a better way?
PeteYodis Moderator, Onshape Employees Posts: 556
@brucebartlett @david_watkins If you click the detail circle on the parent view, you should be able to then click the center-point of the detail circle to drag and re-associated the detail view center.5
@PeteYodis I think we need some improvement here as well.
