Enable me to set object specific snap to vs positional snap to
isaac_oneil
Member Posts: 15 ✭
I am having issues (and maybe i just don't know what I'm doing as I am new) with the way objects snap together and behave after that. It seems like objects that I create snap to the corner of the 3D/2D object but after I create an object around it using those same points, it won't let me delete the original object so that I have created a perfect shell to the dimensions I need.
I'm afraid I don't understand what you're asking. Can you post a video or screenshots of what you mean by 'objects'. Are you talking about snapping in a sketch? What kind of geometry are you trying to create?
https://www.onshape.com/videos/sketching-basics-onshape
https://www.onshape.com/videos/dimensions-and-constraints
https://cad.onshape.com/help/Content/sketch_basics.htm
