How to delete SwiftCalc projects?
I am using the public plan of Onshape. So I can use SwitfCalc App for 3 projects. Now I want to delete those 3 projects to generate new ones. SwiftCalc tells me to open the linked documents in Onshape to delete the link!? How do I do this? I did not find the way of managing those links.
    You should be able to just delete the SwiftCalcs element within the Onshape Document.
  • andreas_scholzandreas_scholz Member Posts: 14
    Hello again, my problem is that when I open my Onshape document that there is no Tab for SwitftCalc project. So I am not able to delete it. I remember to having deleted the Tab after some fruitless calculations in SwiftCalc.
    I see what you mean. Please open a support ticket with them using the ? menu within SwiftCalcs.
