Exporting solid
Hi, I would like to export to a STEP or Parasolid file so I can import into Mastercam. It seems like from the partners page, Mcam integration might be in the works. To make somethign right now with the product I would need to export though. STL is ok for printing or even surface toolpaths, but prismatic parts I need a generic file. Is there a way to export anything other than a DXF of a face or an STL of the entire part???
You can right click on the part studio tab (at the bottom of the page) and choose "Translate". You can translate to multiple formats which would appear as new tabs in your document. You can then right click on these new tabs and download the translated files. (https://cad.onshape.com/help/#translation.htm)
AG
