Etching
fmafma Member Posts: 87 ✭✭
Hi!
I'm working on a BB-8 dome
and I would like to etch the small lines
How would you do that? I was thinking to use the Sweep tool, but how can I build the path on the dome surface?
Thanks for suggestions.
    edited June 2017
    using intersection edges between some tool bodies and sphere (create a copy in place of sphere and make intersection body that contains contour edges that lie on sphere)
  • fmafma Member Posts: 87 ✭✭
    It would be interesting to be able to put 3D points, with constraints (on a surface, an edge...), directly in 3D space, as we put 2D points with constraints in sketches... Then, using 3D curves, it would be very simple to do that.
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 225 image
    This is a great example of when to use 'Up to with offset.'
    1. Create your desired sketch region on a plane
    2. Extrude it some amount
    3. Add a second direction (I like dragging the second end direction manipulator to make sure I have my directions correct)
    4. Make the end condition 'Up to face' and select BB-8's head
    5. Add an offset that is the desired depth into the head
    May the force be with you,
    Jason
    Support & QA
    Nice! Thanks for the tip.
