How do I make a line that will be used for sweep removal following a curve in 3d?
I need to make a hole inside the wall of a hollow cylinder, like a pipe.The hole in the pipes wall that starts on the inside of the pipe. It then punches into the pipe and runs within the wall down a portion of the length. It then needs to turn 90 deg. to the right/left, staying within the wall of the pipe, and follow the curvature of the pipe for a set number of degrees relive to the central axis of the pipe. After the hole follows the curvature of the pipe wall it will need to turn 90 deg. in the same direction that it did before (right/left) and back track the way it came and come out the side (the outside, side) of the pipe. The hole that is traced can be any shape as long as it stays within the walls of the pipe. I hope you can help!
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
Check the document link. The angle is driven by a dimension in Sketch 3. Right now I believe it's set to 120deg, but you can change it to whatever you want.1 -
There are a few ways to create a rotated plane. In this example I used 3 points - 2 pts from the angled line in Sketch2 + the origin. I could have also rotated the front plane about a central axis, but that would have required more effort to keep linked to the arc angle.5 -
Just make a copy of my document and go through the feature tree step by step.5 -
I tend to figure things out on my own, but there are plenty of videos on Onshape's Youtube channel.
4
Can you share your document here so we can help you? Just paste the URL here.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/120003ac961d7f63d3177c75
https://cad.onshape.com/documents/9518e2ebfdee494b44d015c1/w/74a84827929d3967bc3f0430/e/c508cc2efcfda5b21a6715f3
They are called Pythagoras cups here is a youtube video that show how they work
