Trouble selecting shapes,edges using query/filters
Member Posts: 29 ✭✭
Have a feature script that imports an excel file with some vertices and creates a sketch with a rectangle and a few circles inside that rectangle that I want to extrude.
Tried long and (too) hard to get it to work.
At the moment my script is not doing what I want.
The extruding results in a filled rectangle and not with the holes (from the circles) which is really what I want.
Understand this is because I do:
var entities = qEverything(EntityType.FACE);
var entities2 = qSketchFilter(entities, SketchObject.YES);
But I'm failing to understand how I could select only the rectangle and exclude the faces of the circles.
It would have been nice to use the names of the id's but I cannot get it to work.
Tried placing all my circle id's in an array and go from there but I't not working.
This is what I have come up with so far. Playing with the entitiesX variables and debug to figure out how to select (actually excluding them in the extrude)  my inner_circles
https://cad.onshape.com/documents/4da2343209e7255f07f4540e/w/a782e962107ee455b65497a8/e/531534ac2a86a8ec2be12f2f
Any ideas?
Thanks!
  • Moderator, Onshape Employees Posts: 5,838
    That's because an inner loop is still a face. Have you tried this?
    qSketchRegion (featureId is Id, filterInnerLoops is boolean) returns Query
    A query for all fully enclosed, 2D regions created by a sketch.
    ParameterTypeAdditional Info
    featureId<a rel="nofollow" href="https://cad.onshape.com/FsDoc/library.html#Id">Id</a>
    The feature id of the Sketch being queried.
    filterInnerLoops<a rel="nofollow" href="https://cad.onshape.com/FsDoc/variables.html#boolean">boolean</a>
    Optional
    Specifies whether to exclude sketch regions fully contained in other sketch regions. A region whose border has a vertex or edge on the outside boundary is not considered "contained." Default is false.
  • Member Posts: 1,221 ✭✭✭✭✭
    did you tried qSketchRegion(id, "filterInnerLoops": true) ?
  • Member Posts: 29 ✭✭
    Thanks for quick turnaround :-)
    Yes, this worked.
    qSketchRegion(sketchID, true);
    It solved the issue partially.
    My biggest issue is trying to figure out how to select/query/filter the shapes I do need.
    My sketch container an inner and an outer circle for each vertices and I would like to add the outer circle faces to my extrude as well. So really sketchRegion and all the faces named circle_inner* but wild carding does seem to be an existing option?
    I.e the part I colored yellow (and all of them).
    Can I build an array of inner circle id's and pass it to the opExtrude some how?
    edited June 2017
    do you really need all this circles in one sketch? maybe better create several sketches each containing only geometry you want to extrude
    Well tried that just now. But I run into the same issue at this stage.
    Started with sketch1 and put my inner circles there. Extrudes successfully..
    Create sketch2 and places my outer circles there. Same result. Need to select all the id's "outer_circle"* at this stage?
    OR could I go for selecting all shapes of the type = circle somehow?
    And.. If I do the circles in multiple sketches it does not give me the option to create the "collars" i'm looking for.
    The yellow part I highlighted in the previous screenshot
    edited June 2017
    i don't really understand what result you want to obtain from those concentric circles. you need a plate with a number of holes, and a collar in each hole, created in place by FS? if it is so you need to create rectangular profile and a number of outer holes in sketch1, extrude it, then create a number of inner and outer circles in sketch2 and extrude it again, all extrudes with filterInnerLoops=true
    This is what I'm trying to accomplish with the featurescript
    So Im trying to learn how to best select the faces I want. Really should be possible with a single sketch and both my inner and outer circles. Making a first extrude using the rectangle and the inner cicles blindly in one direction and then a second extrude opposite direction and only using the faces created inbetween the inner and outer circle.
  • Onshape Employees, Developers, HDM Posts: 565
    Two sketches seems like by far the simplest solution.
    Sketch 1 should include the surrounding rectangle and the outer circles
    Sketch 2 should include the outer circles and the inner circles
    Both sketches can then be queried with qSketchRegion(...true...) to get the desired content of the two extrudes (Sketch 1 to the shorter depth, Sketch 2 to the longer depth).
    A single sketch would be much harder to work with, since querying the "right" regions isn't trivial. With a sketch, the functions you call draw lines, but the outputs you want to query are regions. If you don't segregate by sketch, you would have to do a lot of tricky work using queries like qContainsPoint() to get the correct regions. There's a similar tradeoff when making this without FeatureScript: With one sketch, you would have to manually pick a bunch of sketch regions to extrude by selecting them, but with two sketches, you can just click the full sketches to extrude.
    Let us know if you have further questions!
    Updated as you suggested Kevin looks much better. Thanks Kevin and other for the quick support!
    Now I just have to make a boolean merge of all the parts.
    Not sure if it's an old feature request or a duplicate but....
    Feature reqs:
    - Generate corresponding feature script code during edit in the UI to simplify further. Probable a quite large request.
    - Allow one to store id's in an array during the creation of shapes to pass them into opExtrude as an example.
    Merging them .... regenerates ok but still as separate solids.. A total of 9 parts.
    First tried to get all bodies and use only tools and not targets.
    Was hoping since I select the target as the one with the rectangle (large solid) they do intersect so they should be possible to merge into a single solid..
            var target = qCreatedBy(id + "extrude1", EntityType.BODY);
            var tools = qCreatedBy(id + "extrude2", EntityType.BODY);
            debug(context, tools); // debug: Query resolves to 8 bodies
            opBoolean(context, id + "boolean1", {
                    "tools" : tools,
                    "targets" : target,
                    "operationType" : BooleanOperationType.UNION
    But.... NOT
    If I use the UI it becomes obvious that union only uses the tools and not targets. So I'm guessing the targets is not taken into account and there is no intersecting solids. So how can I merge all solids in the context?
    if boolean operation type is union then you need only tools - use "tools" : qUnion(tools,target)
    edited June 2017
    Would be nice if + was overloaded for the map type.
    <div>var target = qCreatedBy(id + "extrude1", EntityType.BODY);
    </div><div>var tools = qCreatedBy(id + "extrude2", EntityType.BODY);
    <span style="background-color: transparent; color: inherit; font-size: inherit; font-family: Flama, sans-serif;">var merge = target + tools;</span>
    </div>
    But this generates :
    &nbsp;Can not add Query (map) and Query (map)<br>
    Or if I could do
    var tools = qEverything(EntityType.SOLID);
    Since:
    <p></p><p>var tools = qEverything(EntityType.BODY);</p>
    returns 90 bodies which are not all solids (or maybe none are??)
  • Moderator, Onshape Employees, Developers Posts: 1,646
    @fredrik_tärnell
    You are running into an issue because our UNION merges all the tools together, as documented in the following:
    https://cad.onshape.com/FsDoc/library.html#opBoolean-Context-Id-map
    You could do "tools" : qUnion([tools, targets]) and not set "targets at all" and your opBoolean would work as expected.
    The better way to do this might be to use 'extrude' instead of 'opExtrude' and supply the following in the definition map:
    "operationType" : NewBodyOperationType.ADD,
    "defaultScope" : false,
    booleanScope : qCreatedBy(id + "extrude1", EntityType.BODY)
    This is the same as selecting "Add" in the UI and selecting the rectangular body as the merge scope.
    Let us know if you have any other questions. Thanks for using FeatureScript!
    edited June 2017
    Thanks Konstantin,
    After adjusting the syntax it worked.... Much appreciated!
    <span style="background-color: transparent; color: inherit; font-size: inherit; font-family: Flama, sans-serif;">var tools = qCreatedBy(id + "extrude2", EntityType.BODY);
    </span>
    </div><div>var merge = qUnion([tools,target]);</div>
    A couple additional resources for you:
    Description of queries in general: https://cad.onshape.com/FsDoc/library.html#module-query.fs
    qUnion specifically (what you are looking for with query + query): https://cad.onshape.com/FsDoc/library.html#qUnion-array
    Thanks @Jake_Rosenfeld! Will try to read-up
    @Jake_Rosenfeld
    But I guess feature script is scripting and not coding in traditional sense but overloading + would make easier to understand.
    Or a push operation if it was a list.
    But never mind it works. But I guess I'll be doing alot more scripting in the future since it's truly awesome!
  • Onshape Employees, Developers, HDM Posts: 1,230
    edited June 2017
    I don't like overloading + for something that is not really addition, but you can.
    Something like
    operator+(q1 is Query, q2 is Query) returns Query
        return qUnion([q1, q2]);
    Be sure to remember to export if using across modules.
    Super @ilya_baran!
