Convert a series of connected lines to a smooth spline
bert_drake
Member Posts: 3 ✭
in General
When drawing a sketch, is there any way to convert a series of lines to a smooth spline, or polyline, like in autocad?
You can use the `Composite Curve` tool to convert multiple curves into one curve when you are using it with other features. You can see the help page here.
Best,
Mike
Here's 3 lines in a sketch:
As Michael says, composite curve:
I wrote this fit spline with feature script that builds a smooth curve through input geometry & fit parameter:
Theres also a fit spline in the curves menu drop down, which is driven by vertices & magnitudes:
So what's the difference in my fit spline & OS's fit spline?
Different approaches:
I follow curvature and they follow vertices.
I follow the input curves based on a tolerance:
Anyway, yes OS can compose curves in many different ways.
