Why no Axis
Just curious as to why there are no Axis in OnShape. Or am I just missing something?
1
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 667
Lonnie said:Thanks for the responses. I understand you can work with out them I just was more curious as to why they are left out. I guess they feel they are just not really needed.
Right now you can use circular edges, sketch entities, and cylindrical faces to infer an axis at the center of circle/cylinder. You can use straight edges or sketch lines as axes as well.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com4
I was annoyed at this lack when I first started using Onshape but I have found that it works fine to not have reference axis. Axis are not needed for mating. For feature construction, the above technique works fine.
Don't get me wrong. I would not mind an axis feature.
I have requested default axis but I got answer that most likely this is not going to happen. Possibility to create axis is under review.
I'm great fan of templates so I would propably just create axises into template studios - should be as good as default.
The template idea is good.
Dedicated sketches would be nearly as good, but here's why I would prefer formal reference axes:
In a complex mechanism design, certain axes are important elements, which need to be available from within various assemblies.
They serve a similar purpose, in models involving lots of rotary movement or translation in specific directions, to what reference planes provide in the more general case.
The ability to easily switch designated reference axes 'on' in those assemblies, in order to access them, and 'off' in order to declutter the model, is valuable.
Such access is required not just for mating, but for measurement, orientation, and "assessment of possibilities".
There may be other ways of achieving the same end, and they may be preferable.
For instance, perhaps the development team could consider a "flagging" approach, where users could flag sketches for key characteristics according to a schema of their own devising, allowing future filtering (for selection, display, or whatever else).
Something like this might be more flexible and powerful, and would not introduce any complications to the models of those who had no need of the capability.
Alternatively, mate connectors might serve dual purpose as reference axes. We can already rename them; perhaps we could be enabled to drag the primary axis longer, to identify those which double as a reference axis, and make the location of that axis stand out in a complex assembly.
1) Axis for linear and circular patterns
2) Tangency direction for lofts or surface patches (along all boundaries)
3) Direction of extrusion or offset or thicken
4) Direction of pull for draft
5) Direction for definition of silhouette edges, split lines, projection of sketches onto faces
