SpacePilot Pro not working with Onshape
fred_lauzusfred_lauzus Member Posts: 4
I have a SpacePilot Pro that I have been successfully using with Solid Edge and NX CAD but I am unable to have it recognize and work with Onshape. The only motion I can generate is a jerky diagonal zooming.
I have downloaded and installed the latest 3Dconnexion driver 3DxWare64_v10-4-10_r2558.exe.
I have rebooted the system, Windows 7 Professional (64 bit) service pack 1
I have tested this with Chrome 59.0.3071.86 (64-bit) and Firefox 53.0.3 (32-bit) with the same result.
The 3Dconnexion dialog will only display the browser name, Chrome or Firefox, and not Onshape.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    @fred_lauzus sorry but you'll have to speak to 3DConnexion. Onshape only responds to the data received through the input device driver.
  • fred_lauzusfred_lauzus Member Posts: 4
    This issue has been resolved. I had previously removed the 3DxNLServer because there was conflict with port 8181. Once that conflict was resolved I reinstalled the 3Dconnexion Navigation Library Server and that resolved the issue.
