How do I create a 3D archtop guitar body part ... multiple issues embedded
I'll try to make this short by stating the end goal and the resources available to me to get there.
I'm trying to create an archtop guitar body part based on a set of purchased plans. For those that don't know, an archtop has a very complex curvature for the top and back. I want to create a part that I can ultimately use to drive a cnc mill to carve the top and back and use as a basis for further modified tops/backs.
So, I bought a set of full scale plans in .pdf format. The intent of these plans is to create full scale templates for tracing onto wood. There are many stated dimensions, but not for the basic curves of body. I am able to convert the .pdf into a .dxf. However, when I try to import it into a sketch, I get a "too many entities" error. I've stripped out all but the body outline (and editing the .pdf is a pain) and that seems to work to allow import into a sketch, but I am limited with that sketch. Even then, the sketch shows the body as hundreds of connected points rather than a single smooth continuous curve.
Taking a different approach, I was able to import the body and contour lines as a single dwg and attempted to use that as a basis to trace the body and contour lines using the spline tool, but I'm left with splines that I can't seem to convert to a single curves. My intent was to create the body outline and the subsequent contour lines on different planes and then loft between them to create the complex archtop shape. I can't seem to do that with the spline based tracings.
So, I'm stuck.
If anyone is at all interested in my struggles, I can share the .pdfs or .dxf files for you to play with.
thanks,
Mark
mjcasey@yahoo.com
So, I'm stuck.
thanks,
Mark
mjcasey@yahoo.com
Its a bit of a mess as I've been experimenting.
https://cad.onshape.com/documents/832a7690c58d9a18f29e31f9/w/a651ab765f4a7387e14d4f9d/e/31c39df5fa616b63458c31e8
As a test, i created a composite curve of each of the outline and the first contour (I figured out why composite curve wasn't working for me) that you created. Shouldn't I be able to loft between the two? When I start the loft command, it won't allow me to select either curve as an a loft profile.
Also, would you mind sharing the steps of importing and scaling to get the appropriate sized part? That is not clear to me and I can see using it quite a bit in the process.
thanks again.
https://cad.onshape.com/documents/32163d7652b7cbaf34e192d2/w/13d059c3cbf186154a1632ca/e/2591166cf15dc3bd4b4dfa42
- Insert a sketch with some sizing geometry. In this case it was the outline from the DXF.
- Create the image file you want, preferrably with dark lines on a white background.
- Import the Image file into OS.
- Open a new sketch and insert the image file.
- Dimension and locate the image so that it overlaps your reference geometry (guitar outline).
I don't think you need to create a composit curve. If you're creating a solid loft, you can use sketch regions instead of curves. The hiccup I came across is the corner in the guitar outline. OS is having trouble mapping the very different shape of the outline to that of the contour. After creating all the contours on separate elevation planes, you may need to create guide curves by running a Fit Spline through a couple common points in all the contours. If you had a couple side profile views in your PDF drawing you could have just traced these guide curves. It would have been much simpler than making 2 dozen iso contour curvesI do actually have side profile section views.
See below.
Of course, I have no idea how I would use them to create the part.
Another thing is the usage of guide curves, I'm afraid we might be trying to do something fancy with the propagation of the 3d spline as a guide curve. You might be better off doing vertex matching only.
So if you remove the outermost profile, and use vertex matching instead of guides you should at least partially get to what you're trying to do.
It would be great if you could file a bug with regards to the guide behavior so that we can look into it more carefully.
Maybe the shape is a little too "organic". It is meant to be hand carved, but I do know folks have successfully used CNC to carve them.
Thank you @mahir for the link. It looks very promising. I'll keep playing with it.
I may be too much of a novice at CAD and certainly at OnShape to tackle this one, but I'm going to get there one way or the other.
Thanks for taking an interest in my project and I welcome any additional feedback.
https://cad.onshape.com/documents/c1aa5bba6a0139ebb12ce0bd/w/7dbd79899d296fb290aca0f0/e/221fb58cf7a7524ff4d663aa
http://https//formlabs.com/blog/designing-a-3d-printed-acoustic-violin/
You might want to look at @william_chelton 's Guitar. Looks like he tackled the arch top geometry a number of lofts, not just one. https://cad.onshape.com/documents/2b44aab91ac41d6cd4b6b5d1/w/3a0372585e6b5f19c9345ef8/e/806ee39592023f4df664e91b
https://cad.onshape.com/documents/2242b8898166583ba40c4ef6/w/9c6fb428ba24cc6146f9651c/e/5dd2f707f7c383f23a7d8dd5
I'm trying a new approach as well. I have cross sections. I'm going to try and use with intersecting extrusion or lofts between them.
We'll see how that works.
