Simulation hub
AZΘRÆN
                    Member Posts: 22 ✭✭
                    When I try to make an account on SimHub I get an error back that says " The server failed ". What could I do to fix this problem? ( I have a model that I would like to test with this software)
Paul_J_Premakumar
                            Member, Onshape Employees Posts: 235
                    I was able to successfully create an account a short while ago. Can you try again? If it doesn't work, you may want to contact SimulationHub support : https://www.simulationhub.com/contact-us .5 -
Jason_S
                            Moderator, Onshape Employees, Developers Posts: 224
                    I have Pinged Simulation Hub, they are aware of the of the issue and are working on it.
If you have an issue with any app, please use the feedback tool to file a bug. Those tickets you make through the feedback tool make it to the Partner directly. I work on getting those issues solved ASAP.
If there are any other issues, please do not hesitate to ask.
Thanks!
JasonSupport & QA5
Thanks!
Jason
