Is there a problem with export?
I have been using OnShape for several weeks now. I have exported several dxf and dwg files. Today (June 12, 2017) as I was duplicating my previous workflows the export function would not work. Same drawing. Same computer. Same network. Is 'export' down at the moment for some reason?
Jason_S Moderator, Onshape Employees, Developers Posts: 222
@MotorcycleWriter,
This is an issue with how Big Blue Saw reads in DXFs. The large circles are coming in fine in multiple 2D viewers, including non-Onshape ones, they come in fine to my multiple cutting programs I use when I export as Release 14 from Onshape. They probably don't support how circles, splines, and arcs are drawn in new versions of DXF.
R11-R12 is the more 'universally accepted' format. Every laser cutter, water jet, CNC i have ran had no issues with R11-R12 and When I upload a file exported with R11-R12 they read the file fine. There are many differences between different versions of DXFs.
So just use these settings and you can continue to use DXFs with your manufacturer.
Thanks!
Jason
p.s.
Instead of copying and pasting, I would recommend the 'Use' command. then you retain the associativity to the other sketch entities. there are too many things that can go wrong, including misaligned holes when copy and pasting then manually making them interact with each other.
Support & QA5
John
(we worked together previously regarding your sketch questions).
I exported the face of the part as DXF and reimported it so that i could compare it to the original.
Here is a link to the public document in which i did this.
The results were an exact match (as shown in this screenshot)
I dont doubt that you are having problems, i just need a little help to reproduce the issue!
As a first level sanity check - you are using a supported browser (chrome, firefox, safari) and that you exported a dxf file by RMB over the face of the part and selected 'export DXF/DWG' ???
There is no difference in what you see between Onshape and a popular 2d cad software (First is Onshape and the second is the other program)
I noticed another comment you had here. Is it possible that the failed export was actually an export of your frame and not an export of the 'merged' sketch?
Best,
Mike
This is what I see in "DIA"
And this is what I see when I upload to BigBlueSaw
And this is what I see when I upload a DWG to BigBlueSaw
This is correct so I will use the DWG. I prefer DXF as they seem to be more widely used and I can 'see' them easier. I have nothing that will preview a DWG other than by uploading to BigBlueSaw. I consider this a workaround and not a true fix.
To generate this model I made two sketches, one with lines and one with circles, because the dimensioning was getting busy. I then combined the images by using "Copy Sketch" then "Paste Sketch Entities" and aligning the two manually with a reference mark on each sketch.
Thanks!
Jason
p.s.
I have also noticed that the export feature is working again. So, I've re rendered my model and will be uploading it to BigBlueSaw again.
Thanks again for all the help! I've got more things I want to make and these new technologies are turning my imagination into things.
We didn't change anything - it was always working
